anyone know if the blacktop rocker cover ( plastic ) will fit on the older silver top cylinder head?
I tried painting my silvertop rocker cover ( went badly wrong! ) so i thought i might try fitting a plastic one instead.
yes it will, ive got one on mine
thank you.
Dont forget though, you need the gasket to match the cover, they are different, so are the fixing screws, longer ones with broad heads or large washers are needed for the plastic cover.
thanks pete. good advice.
plastic cover is taller than silver top item. Do you have the clearance ?
yes, i think so.
