Is there much advantage to be gained from having the later Ford 2.9i V6 lump over the 2.8i, or is the difference negligeable?
Thanks in advance,
Mart
Christ, where do I start?
2.9s good bits:-
Slightly more power, more potential for tuning due to three-port heads on the exhausts, better inlet manifold on the EFI, chain driven cam instead of
weird-arse plastic gears
That sort of thing. Even without these bits, the 2.8 is still a good (if rarther heavy) engine.
Don't forget the 190bhp cossy version of the 2.9. You should be able to pick one of those up somewhere!!!!!
Someone I know has turbo manifolds and much experience of blowing the 24v V6
http://www.chevroletls1.com
John
I got one at the front of my garage
Missing most of the injection though
Dead sexy engine mind
Early engines snap timing chains
