getting the zetec to run
dunk3 - 22/9/08 at 06:39 PM
hi again what else would i need to get my 2.0 black top running on injection using a megasquirt. cheers
novacaine - 22/9/08 at 06:52 PM
some form of suitable inlet and exhaust manifolds
it is likely that you will have to chop the sump (if its going in a 7 that is)
and some way of controling igntion
jacko - 22/9/08 at 06:56 PM
Petrol ?that may help
I will get my coat
Paul TigerB6 - 22/9/08 at 07:37 PM
Gonna be using bike throttle bodies?? If so then a fuel pump from the same bike might be a good idea (and might influence the design of your fuel tank)
Sump (and oil pickup pipe) will likely need shortening (steel pan so not too bad), You'll probably want to consider a lightened flywheel, suitable starter motor / clutch / alternator etc. Bogg Brothers for an inlet manifold maybe??
jacko - 22/9/08 at 07:57 PM
Dunk send a u2u to Tim Windmill on here he has just finished the same set up as you his car is on the road so will know all you need to now + maps for the mega/ sq
Jacko
