I used to have a bookmark saved for a company that did custom lengths of belts (i need a long 5 tooth one, the kind that will fit on a micra
alternator/crank pulley) Anyone know of where I can get one? I tried searching the site but can't for the life of me remember how I found it last
time!
[Edited on 27/9/08 by Benzine]
Halfords do a huge range which you may be able to select from if you measure up.
I looked in halfords but the longest one they had wasn't long enough
I get mine from my local motor factor - they have a huge range , just hanging from the rafter's
How long do you need ?
[Edited on 27/9/08 by clairetoo]
Im sure a proper factors like partco or somewhere must have something.
My supplier jayar have hundreds.
Just tried autostop (local factor) and they've ordered me one ^___^
Good point
Also camskill have a huge list of 6-toothed belts (which I needed in the end, not 5 tooth as said in my first post!):
Big list of belts from about 80cm to 2.6 meters
Thought I'd post above link incase anyone searches the forum in the future
