twin 40 and twin 45 manifolds.
Danozeman - 4/10/08 at 10:54 AM
Is there actually an difference between the 2?
You see some listed as fitting any and some lisetd to fit only one.
dubstar_04 - 4/10/08 at 11:37 AM
Most manufactures do differ the bore size between the 40mm and the 45mm. however they are interchangeable due to using the same bolt holes.
I would advise buying the size you need as using the wrong one will inhibit performance.
Also be very careful:
if you are going to buy one as I have had a few that have been very poor quality castings and i have had to spend hours cleaning them up to an almost polished look which looked daft when nothing else was shiny!!
cheers,
Dubstar_04
Danozeman - 4/10/08 at 11:48 AM
I thought they must be different bore sizes.
