Hi all,
I am currently in the design stage for creating a hybrid "bolt-on" system for aftermarket fitment (thats you guys!). However i am really
struggling to find some dimensions for bellhousing bolt patterns!
Is there anyone out there that can help me, i am looking for drawings/dimensions of any of the following:
-Any "ford pattern" bellhousing bolt pattern dimensions.
-Duratec (or mazda MZR) bellhousing bolt pattern dim's
-Any other common 4cyl engines used in kit cars, bellhousing bolt pattern dim's again
Any help would be greatly appreciated, and when the project starts getting a little further than it is at the moment i shall post up some info and
pictures.
Regards
Edd
[Edited on 14/10/08 by ghetto_eddie]
Get some different gearboxes/ bellhouses and measure them! Then you can also trail fit the prototypes.
Post edited as i have sourced the details for a type-9 transmission (quaife technical support!).
The reason i dont want to take my measurements directly off the block is to do with tolerances. A proper engineering drawing will let me know all the
details i need to produce a high quality fit between bellhousing/engine. Measuring from the block is time-consuming, innacurate and gives me no
details on tolerances!
Regards
Edd
