intercooler pipes
beaver34 - 27/2/12 at 08:12 PM
im using 63mm or 2.5" hard pipes, i will need to make some intercooler hoses to join the silicone ends on my engine build
can you buy a tool the bead the ends of normal pipe? as cooler pipes on eBay seem really expensive
what have you guys done?
thanks
madteg - 27/2/12 at 08:30 PM
Mine are just clamped on to straight pipe, i am running 15PSI and they have not blown off yet.
beaver34 - 27/2/12 at 08:38 PM
im looking at running 20 psi, just dont want the hassle, first place its going is london on a trailer to get mapped carnt afford it to go wrong
imp paul - 27/2/12 at 08:46 PM
i made this tool and it works sweet to put a bead on pipe home made locost style pipe sw
all you need is 1 mole grips
2 exhaust clamp
3 very thick steel washer weld both to the grips as above and as you can see it does a nice job on steel tube cheers paul
[Edited on 27/2/12 by imp paul]
macc man - 27/2/12 at 08:46 PM
If the pipe is of a thin gauge you could use an Oyster tool to form a bead. Used to be on sale in B&Q but getting hard to find now.
mark chandler - 27/2/12 at 08:47 PM
You can easily make a beading tool, just modify an old pair of mole grips.
If you have a google you will see hand held jobs they just have a ball and socket, so grind up a stamping edge and socket in the jaws.
Regards Mark
Chippy - 27/2/12 at 10:51 PM
In one of Dave Walkers write ups in PPC he just tapped three outward facing dents in the end of the pipe, seemed to work for him. HTH Ray
rdodger - 27/2/12 at 10:53 PM
Intercooler pipe beader | eBay
westy turbo - 28/2/12 at 11:34 AM
merlin and many others have them in different bends,angles. or u need custom do them?
beaver34 - 28/2/12 at 11:46 AM
need to custom them, and that work sout cheaper as far as i can see
