Time to start preparing for mounting the engine.
From what have people generally made their engine mounts. I intend to use the Fiesta Gearbox mounting for the rubber (as per MKIndy) but wondered
what's suitable for the rest of it.
I'm currently considering two things: using box section (50mm each side?) but would 3mm RHS be strong enough?
Or, making up an 'I' (end profile) bar from three strips of 3mm steel- again, would 3mm be enough.
With either of these I'd cut the ends off at 45° or so and weld a 3mm flat plate on each end.
How have others done theirs? And are the above at all suitable? Bear in mind it's the beast Pinto engine!
Thanks,
James
We are thinking of a very similar solution using box section to mount our zetec. We had the same worries about the strength... so instead of using a single length of box on each side we are intending to use two. Of course the way the plate mounts to the engine may stop you doing this.
I used the cast ali Sierra mounts, there's a Diagram at:-
http://www.gibbs111.fsnet.co.uk
on build tips
Chris
Hi James. Ive used 50mm RHS to fabricate mounts exactly as you describe, with a nut welded at the back of the plate for the engine mount to screw into (gone for Cortina round mounts) as you wont be able to access it with a spanner. They should be plenty strong enough, after all, the engine sits on just two pieces of 25mm RHS with a plate welded in between!
From what have people generally made their engine mounts. I intend to use the Fiesta Gearbox mounting for the rubber (as per MKIndy) but wondered what's suitable for the rest of it.
Thanks,
James
i had a steady bar made up - a lot like the mini has - at the rear of the head, rubber mounted. That, combined with the two engine and std gearbox
mounts really firmed things up.
Im not making your kinda hp and torque on my car tho.
atb
steve
