Author: Subject: Temp sensor adapter
prawnabie
posted on 9/11/08 at 08:51 PM Reply With Quote
Temp sensor adapter
Hi guys,
Im wiring in my acewell and the temp sensor is a 10mm 2 wire jobbie. The engine is a crossflow.
How have you guys put the temp sensor in? Should I try and find an adapter to screw into the head, or put a take off in the top hose?
Shaun
[Edited on 9/11/08 by prawnabie]
DIY Si
posted on 9/11/08 at 09:06 PM Reply With Quote
Depends where you want to measure the temp really! Either is ok, as long as you remember where it is, as the temp may vary by a few degrees from place to place around the engine.
Sun Tzu, The Art of War
posted on 9/11/08 at 10:36 PM Reply With Quote
Remember the coolant in the top hose will not be at engine temperature until the thermostat opens . The hose to the heater from the inlet manifold will be the hottest part of the cooling system. If you don't have a heater its a good idea to fit the hose routed direct to the water pump to aid bleeding etc . I made and fitted an adaptor to my coolant temperature sensor into said hose when I converted to injection.
martyn_16v
posted on 10/11/08 at 08:58 AM Reply With Quote
ETB instruments sell thread adaptors. Only a couple of quid each
