Author: Subject: Pinto C'Head Ball Pin Adjuster Nuts
James
posted on 27/1/04 at 11:57 AM Reply With Quote
Just putting my cyl' head back together
When I loosened the ball pin adjusters I didn't as Heynes says "Note their locations for use when refitting!" So I've no idea how much to wind them back up now that the rockers are on top.
Any idea how I should get this right?
I'm guessing it's with a feeler gauge between the rocker and the cam but not sure!
Any info greatfully recieved!
Thanks,
James
timf
posted on 27/1/04 at 12:21 PM Reply With Quote
feeler guage between cam and rocker pad
follow the destructions in the haynes manual and you wont go far wrong
posted on 27/1/04 at 12:28 PM Reply With Quote
Turn the cam so the lobe peak is facing up and then check the gap between the base of the lobe and the follower 0.20mm inlet 0.25mm exhaust I reckon should do it.
yours, Pete.
James
posted on 27/1/04 at 02:32 PM Reply With Quote
Thanks guys!
James
James
posted on 28/1/04 at 09:16 AM Reply With Quote
Got that job done now. I've never used feeler gauges before!
Thanks again,
James
posted on 28/1/04 at 09:32 AM Reply With Quote
It's all about getting your hands dirty and learning.
yours, Pete.
Metal Hippy
posted on 28/1/04 at 09:34 AM Reply With Quote
I've done a fair bit of feeling in the past....
Cock off or cock on. You choose.
mackie
Did you get your hands dirty?
mackie
posted on 28/1/04 at 09:36 AM Reply With Quote
You've just inspired me to whip the cover off my girlfriends Fez and actually adjust the valve clearances. It sounds like a bloody sewing machine. It is an old banger that cost next to nowt though.
theconrodkid
posted on 28/1/04 at 09:45 AM Reply With Quote
they all sound like that,doubt if you could quieten them down
who cares who wins
pass the pork pies
