Author: Subject: Coolant for Golf engine
James
posted on 3/3/04 at 06:06 PM Reply With Quote
Not sure if this is an Anything Else or at all relevent to Locosting:
I've got a MKII Golf.
When buying some anti-freeze recently the guy at GSF told me to make sure I bought the same stuff as had been used before. He didn't tell me why tho.
Is it important to do this? I can't really see why unless maybe if I was just topping it up. As it happens I want to drain the whole system.
James
posted on 3/3/04 at 06:23 PM Reply With Quote
Ethlyn glycol anti freeze is the type you should use . DO NOT use the newer synthetic anti freeze which I'm told reacts with ethlyn glycol and turns to a gel blocking the cooling system causing overheating problems. Rusty
Mark Allanson
posted on 3/3/04 at 10:11 PM Reply With Quote
Golf Mk3 from 96 used G12 (VAG speak) antifreeze, it pink. Rusty's right, don't mix it. Yours should use ordinary old fashioned blue
