goodall
posted on 9/8/09 at 09:11 PM |
type 9 bolt pattern
hi been trying to measure the bolt pattern between the bell housing and the gearbox this evening, allow i have fairly certainly decided the distance
between the bolt holes, i cant work out the center on the input shaft relative to the holes.
i need to know this for so i can make a adaptor between the t9 and the 924 bell i have bought. its simpler on the bell, the input shaft hole is in the
middle of the bolts.
so i need a drawing or some info on the bolt pattern of a type 9
thanks stephen
owelly
posted on 9/8/09 at 09:54 PM |
I photocopied a bellhousing. Is that any good??
http://www.ppcmag.co.uk
goodall
posted on 9/8/09 at 10:02 PM |
might work, could try importing it into autocad and measure it using that using one known size
i bought the box without a bell which i think may be making it more difficult for me
did you use the photocopy to get a plate cut on the profiler when you made your custom bell owelly?
it could make a good article in ppc making bells and adaptors ete
Trev Borg
posted on 9/8/09 at 10:03 PM |
like this ?
Before you judge a man, walk a mile in his shoes.
By that time, who cares.
You're a mile away, and you've got his shoes
owelly
posted on 9/8/09 at 10:15 PM |
Come to think of it, I may have that end on CAD.
Trev Borg
posted on 9/8/09 at 10:16 PM |
do you recognise the writing
[Edited on 9/8/2009 by Trev Borg]
goodall
posted on 9/8/09 at 10:21 PM |
quote: Originally posted by Trev Borg
like this ?
perfect! i found that the dimensions seemed all be in imperial, how ever if well enough measured in metric will be good enough, as will locate
concentrically on gearbox spigot
Trev Borg
posted on 9/8/09 at 10:25 PM |
i think this is from owelly's original pattern for the alfa to type 9
owelly
posted on 13/8/09 at 06:20 PM |
Yup. Those are my scribblings! I can't guarantee they are perfect but I've made three bellhousings, and a handfull of spacers and
they've all fit!!
RichardSIA
posted on 26/11/13 at 06:26 AM |
Would you have a sketch of the Alfa side?
I'm trying to match up a T9 and Alfa Spider 2000 engine for my Marcos.
I've used punches to map out the Alfa side fairly closely but a proper drawing would be better.
How thick did you make your adapter and what did you do about the overlapping hole at the bottom?
My T9 has a cover over the layshaft retained by three bolts.
That cover comes up under one of the Alfa bell attachment bolt locations.
Does that cover mean this is a V6 box?
It was sold to me as coming from a Merkur.
At these fuel prices I want it leaded, five-star, and my windscreen cleaned!
owelly
posted on 26/11/13 at 09:27 AM |
The Alfa engine I used was the V6. I didn't make adaptor plates as such, but scratch built bellhousings. I may have a couple of bellhousing
photocopies tucked away somewhere but I doubt they'll be any good to you!
