Author: Subject: Skimmed pinto head
gjn200
posted on 12/4/04 at 10:51 AM Reply With Quote
Skimmed pinto head
How do you tell if its been done previously? Is there a dimension from rocker gasket face to the cylinder face?
<- Me!
gjn200
posted on 13/4/04 at 09:55 PM Reply With Quote
Come on guys! loads of people have pintos, it can effect timing and fueling surely people have'nt just put em'on and hoped
<- Me!
macspeedy
posted on 13/4/04 at 09:58 PM Reply With Quote
Try phoning these guys they do all the stock car engines pintos, in my area
Engine services, ask for Alec, not at lunch times.
0131 440 0201
Hope that is of help
Graham
gjn200
posted on 13/4/04 at 10:00 PM Reply With Quote
Ta, burtons said 'lets see it'
<- Me!
Mark Allanson
posted on 13/4/04 at 10:25 PM Reply With Quote
My head is off, but at work, I'll measure it tomorrow
Mark Allanson
posted on 14/4/04 at 06:10 PM Reply With Quote
..as promised, it is EXACTLY 95.000mm from rocker gasket face to cylinder deck face, assuming mine has not been skimmed previously, but the exact measurements look like it was designed that way
NS Dev
posted on 14/4/04 at 06:44 PM Reply With Quote
unless it had been dramatically skimmed (which would only normally be the case with a decent head i.e. bronze guides, ported, bigger valves etc etc then I wouldnt worry too much. The timing is fairly easy to set up as long as you can hear pinking (that's basically how it would be done on a rolling road anyway) and you shouldnt trust the factory setting re the timing because on a pinto this is notoriously innaccurate anyway! Fuelling wise, you should get the carb jetting checked quickly on a rolling road anyway just to be sure, in which case it doesn't really matter. Only way to accurately check the CR is the measure the chamber cc's and piston heights etc etc and do it that way. (but as I said, I wouldnt worry unless building a competition engine)
gjn200
posted on 14/4/04 at 08:05 PM Reply With Quote
Cheers chappies!
<- Me!
