givemethebighammer
posted on 12/4/04 at 06:23 PM |
fuel pipe - did I make a ****
Just realised I have used 10mm microbore not 8mm microbore as fuel pipe. I have a facet blue top fuel pump capable of delivering about 5-6psi of
pressure, however this will be regulated to 3-4psi for my twin webers.
Does it matter that I have used 10mm not 8mm pipe ?
macspeedy
posted on 12/4/04 at 06:27 PM |
no not at all
Mark Allanson
posted on 12/4/04 at 06:29 PM |
You can get 10-8mm converters in yorkshire fittings to make it even easier
RoadkillUK
posted on 12/4/04 at 06:30 PM |
Just use a thirstier engine, no point in wasting the pipe.
Roadkill - Lee
www.bradford7.co.uk
Latest Picture (14 Sept 2014)
givemethebighammer
posted on 12/4/04 at 06:34 PM |
phew, just for a moment I though I was going to have to rip it out and replace it. Don't worry about the 10mm to 8mm converters. The rubber fuel
pipe I have at each end was a tight fit anyway. Plus I put a single flare on each end of the copper pipe as well to stop the pipe popping off.
Got a feeling my 2.0L zetec with the twin 45's is going to be thirsty anyway (well it will be with my heavy right foot !!!)
thanks people panic over
