Author: Subject: Water and Oil Sensors
greggors84
posted on 19/5/04 at 12:08 AM Reply With Quote
I have 2 screw in sensors on the block of the pinto are these for oil pressure and oil warning light? Where does the water temp sensor go? I have a switch that screws into the rad, is this just for the fan switch?
Ive done a search and couldnt find anything of relevance.
Chris
The Magnificent 7!
timf
posted on 19/5/04 at 07:29 AM Reply With Quote
temp sender on a pinto is on the front of the cylinder head on the inlet side looks a first glance like a bolt hole.
greggors84
posted on 19/5/04 at 12:25 PM Reply With Quote
Yeah got that one, so is the other one the oil pressure? Its bigger and on the same side but lower down and further back. I had them wired up but i spoke to someone yesterday who didnt think the water temp sender went in the block.
The main reason i wanted to know is i need to know how to wire up the low oil pressure warning light.
Chris
The Magnificent 7!
