Author: Subject: How much
adz h
posted on 29/5/04 at 07:18 PM Reply With Quote
How much
I've been quoted £1,233 for webber alpha kit for a zetec engine. Is that right?!
zetec
posted on 29/5/04 at 07:51 PM Reply With Quote
Probably. Best check out other options before handing over hard earned. Weber set up can only be changed by a Weber dealer. Other ECUs can be set up with a PC or laptop with simple software. I used Emerald which was supplied with a zetec map which was fine tuned on a rolling road, and I am able to alter anything I like with ease...idle speed, fueling, coolant fan on/off, ignition etc etc.
As I say there are lots of options. Checkout Jenvey web site, they give loads of info on injection and ECUs and links to some of the better known companies.
adz h
posted on 29/5/04 at 08:02 PM Reply With Quote
I haven't got any of the injection system for the engine is there any other option, other than webber carbs?
macspeedy
posted on 29/5/04 at 08:03 PM Reply With Quote
yep there are lots of manufacturers of throttle bodies try google
adz h
posted on 29/5/04 at 08:05 PM Reply With Quote
Thanks people
cosworth
posted on 29/5/04 at 08:26 PM Reply With Quote
Try ShawSpeed they do lots of engine kits
email info@shawspeed.com
mangogrooveworkshop
posted on 29/5/04 at 08:33 PM Reply With Quote
STUPID QUESTION Has anyone got through SVA with a late model zetec on carbs no cat?
zetec
posted on 29/5/04 at 09:56 PM Reply With Quote
I suspect very unlikely. I have heard people passing later test with carbs and a special cat (which fell off on the way home).
phelpsa
posted on 30/5/04 at 06:58 AM Reply With Quote
£1233 sounds quite good from what I have read in 'Performance ford' magazine. The going rate at the moment seems to be nearer £1400.
Adam
britishtrident
posted on 30/5/04 at 08:07 AM Reply With Quote
Emerald is a better bet see info on Dave Andrews excellent site -- Dave Walker is one of "us" --- good guy
NS Dev
posted on 31/5/04 at 08:25 AM Reply With Quote
Adam
I completely agree! That sounds a good price!! (though obviously not "locost"!!)
The ecu alone (£500ish) may be much cheaper but you are not going to get the throttle bodies cheap, direct from Jenvey the cheapest ones are around £385 +vat for the ones that fit onto a weber inlet manifold (which itself is another £70 +vat if bought new) the throttle pot is at least £20 etc etc etc
