BMF
posted on 25/6/04 at 08:51 AM |
Vauxhall XE Clutch
I have been offered a SBD 4.7kg lightened flywheel (original is 6Kg), and 2x SBD Quad Padle plate Helix clutches, release bearing, 2 release arms for
£150.00
I am not sure how suitable these quad padle clutch plates are for road use.
Any ideas?
If anyone wants the Clutch plates, perhaps we can come to a deal!
Cheers Ben
andrew-theasby
posted on 25/6/04 at 07:36 PM |
Hi, cant really help about the clutches but if your just after a flywheel, theres a guy selling em on ebay for about £85 if i remember rightly. Might
be of interest to you (no connection)
NS Dev
posted on 26/6/04 at 07:19 PM |
it depends on whether they are sprung centre paddle plates or unsprung. If they have torsion springs like a "normal" clutch then they are
ok for road use ( a bit sharp but ok) if they are just a solid plate with no springs then they are a bit rough for road use, they are totally in or
out, no in-between!!
They are the right diameter and spline for your application I presume!!??
If they are as above then buy them!! The helix plates are tough and can be "re-paddled" very cheaply when necessary.
ned
posted on 28/6/04 at 08:32 AM |
I contacted the guy selling the light flywheels on ebay. they weigh about 2.5 kg's, but you'll need a 7 1/4 inch (race) clutch cover as
the standard vauxhall one won't fit. With the cover and clutch plates to suit it would become expensive..
Ned.
beware, I've got yellow skin
