Author: Subject: flywheel & torque
PaulBuz
posted on 29/6/04 at 07:47 PM Reply With Quote
flywheel & torque
Hi all
i'd like to lighten my flywheel as the dohc one is a fairly lardy lump!
thing is , the dohc engine has very good low down torque. I know that lightening the flywheel will improve engine pick up, & to some degree will reduce engine braking, but to my thinking the torque should remain the same..........unless anybody knows different!
Paul
200mph
posted on 29/6/04 at 08:50 PM Reply With Quote
torque is a rotational force produced by the engine. Flywheel weight has no effect on the torque produced, only what happens to it afterwards.
Mark
Andy S
posted on 29/6/04 at 09:58 PM Reply With Quote
Have a good read of the info on
www.pumaracing.co.uk
I recall quite a good explanation there.
Andrew
PaulBuz
posted on 30/6/04 at 05:42 PM Reply With Quote
britishtrident
posted on 30/6/04 at 07:01 PM Reply With Quote
Reducing the rotational inertia will not reduce the torque but it will make the engine easier to stall.
posted on 30/6/04 at 08:37 PM Reply With Quote
If you take a lot of weight off it can affect the tickover but I doubt you would be able to remove that much from a standard flywheel without making it dangerous.
