pekwah1
posted on 7/8/11 at 08:22 PM |
No fuel from the tank....
Hi Guys,
So i have a 1300 xflow in my striker.
It's using the mechanical fuel pump on the engine.
I have had the engine running with no problems so far, but i think last time i tried to start i was out of fuel.
Anyway, just fueled up again today and the fuel is getting nowhere.
The fuel filter is just after my tank, and i'm not seeing any fuel going through, definitely nothing going to the carbs.
So are mechanical pumps likely to fail?
Is there any easy way to check?
Thanks,
posted on 7/8/11 at 08:30 PM |
yes.
remove plugs, disconnect the hose to the carb(s) and whizz the engine over. if after 1/2 minute there is no fuel, either there is a blockage, no fuel
in the tank, a significant air leak in the hoses or the pump has failed.
pekwah1
posted on 7/8/11 at 08:33 PM |
yeh i've already done that, as said, no fuel coming through at all.
just trying to establish how i can tell it's definitely the pump, although i don't see how it could be anything else really...
jacko
posted on 7/8/11 at 08:38 PM |
Is the fuel pipe coming out the tank at the top or the bottom ? you may have to prime the system if from the top
pekwah1
posted on 7/8/11 at 08:39 PM |
from the bottom sir
macc man
posted on 7/8/11 at 08:40 PM |
If you remove the pump from the engine you will see a lever which acts on the camshaft lobe. If you move it up and down you will see fuel squirt out
of the pipe going to the carb. If not strip it down you will probably need a repair kit as the diaphragm is damaged.
pekwah1
posted on 7/8/11 at 08:41 PM |
cheers macc man, that's what i was kinda after.
I will rip it apart and see what's going on.
jacko
posted on 7/8/11 at 08:46 PM |
Could the pipe be blocked with crap how about blowing down the pipe from the pump end not though the pump ?
Is the air hole blocked causing a vacuum in the tank?
[Edited on 7/8/11 by jacko]
pekwah1
posted on 7/8/11 at 08:48 PM |
fair comment, i don't see how it could be blocked, it's never even seen the road, only been ran still, and everything else is already
sealed. But saying that, a nice easy test, i'll give that a go first!
austin man
posted on 7/8/11 at 09:22 PM |
common problem is alluminium particles in the tank from the drilling and cutting out for the sender unit. followed by sealand used on the
afforementiones. Blow back into the tank via the fuel outlet I would use an air blast gun this may clear it but it will return if its not fully
cleaned out
steve m
posted on 15/8/11 at 10:26 AM |
Andy,
I will dig out one of my spare pumps !
steve
