Cozza
posted on 4/9/11 at 08:21 PM |
Problems with a part-build
Nightmare. I'm just getting my head round what I've got in my part-build (red top c20xe with a Manta gearbox). I've discovered two
major problems:
In order to avoid the bottom of the inlet manifold interfering with the steering column, the previous owner has sliced the bottom of the manifold
off!! There's a 1 inch square hole at the bottom.
The gearbox casing is touching the vertical rail to the left of where the pedal box would go/to the right of the front of the transmission tunnel.
Can anybody offer any advice or reassurances?
NigeEss
posted on 4/9/11 at 09:54 PM |
Post some pics, they tell a thousand words...
Cozza
posted on 5/9/11 at 06:52 AM |
Ok. I'm off to work now but will put them up tonight. Cheers'
Ben_Copeland
posted on 5/9/11 at 11:41 AM |
Id strongly suggest binning the standard injection system and going bike throttle bodies or similar. More power and much easier to fit.
Also sounds like either the engine isn't central in the tunnel or it's too far back into the tunnel. I'll await the pictures to make
my final comments
Ben
Locost Map on Google Maps
Roadster
Enter Your Details Here
Cozza
posted on 5/9/11 at 06:11 PM |
http://i981.photobucket.com/albums/ae297/CozzaNess/DSCN0699.jpg?t=1315246757
http://i981.photobucket.com/albums/ae297/CozzaNess/th_DSCN0697.jpg?t=1315246757
The first pic shows the gearbox housing fouling the upright.
The second pic (taken upside down) shows the bottom of the inlet manifold with an approx 1" square section removed!
Any thoughts?
[Edited on 5/9/11 by Cozza]
Ben_Copeland
posted on 5/9/11 at 06:20 PM |
quote: Originally posted by Cozza
[img]G/DCIM/100NIKON/DSCN0697[/img]
[img]G/DCIM/100NIKON/DSCN0699[/img]
Any thoughts?
U need to upload them to the Photo archive first !
Ben
Roadster
Cozza
posted on 5/9/11 at 06:21 PM |
Sorry. I've re-done them with a link to Photobucket
Ben_Copeland
posted on 5/9/11 at 06:26 PM |
Errr from what i can tell the engines too far into the transmission tunnel or too far over to one side.
The inlet manifold is cast so a real pain if you want to weld it. I'd still go with the replacing with carbs/ tb's
Ben
Roadster
