Author: Subject: What engine is this?
Trev Borg
posted on 26/9/11 at 07:01 PM Reply With Quote
Just picked up my midtec spyder.
The car has a renault 21 2.0 8v motor.
Anyone know what the engine code would be for it
Is it a J7R?
Douvrin engine ?
might need to get some better pictures of it
[Edited on 26/9/2011 by Trev Borg]
Before you judge a man, walk a mile in his shoes.
By that time, who cares.
You're a mile away, and you've got his shoes
Mark Allanson
posted on 26/9/11 at 07:21 PM Reply With Quote
My book lists 7 variants of the J7R, 2 of which are 12v. Do you have any more info, like what throttle body and which injection?
Trev Borg
posted on 26/9/11 at 07:41 PM Reply With Quote
I believe it is from Renault 21 savanna.
posted on 26/9/11 at 07:42 PM Reply With Quote
There may be a plate riveted to the block near the flywheel end under the exhaust manifold with the info you need??
Mark Allanson
posted on 26/9/11 at 07:52 PM Reply With Quote
Your choices are
J7R A7-50 - 69KW
J7R A7-51 - 90KW
J7R 7-52 -131KW (TURNIP)
J7R 7-56 - 131KW (TURNIP)
J7R 7-46
J7R 7-47
All run injection, either Renix, Siemens, Multipoint MPI, or Bendix
If you have the engine age or injection details, I could probably isolate it.
Trev Borg
posted on 26/9/11 at 08:09 PM Reply With Quote
2.0 L (1995 cc) petrol SOHC 8-valve I4 MPI; 120 PS (88 kW; 118 hp); top speed: 200 km/h (124 mph); 0–100 km/h: 9.7 s (Available in RX, TX, GTX and TXE models)
2.0 L (1995 cc) petrol SOHC 12-valve I4; 135 PS (99 kW; 133 hp); top speed: 203 km/h (126 mph) ; 0–100 km/h: 9.8 s (available in the TXi and TXi Quadra models)
2.0 L (1995 cc) petrol SOHC 8-valve I4 MPI turbo; 175 PS (129 kW; 173 hp); top speed: 227 km/h (141 mph); 0–100 km/h: 7.2 s (available in Turbo and Turbo Quadra models).
2.0 L (1995 cc) petrol SOHC 8-valve I4 MPI turbo; 162 PS (119 kW; 160 hp); top speed: 217 km/h (135 mph); 0–100 km/h: 8.6 s
these are the ones I found.
The engine now has a DARA carb on. running with an Emerald M3D management system
Volvorsport
posted on 26/9/11 at 08:33 PM Reply With Quote
its deffo an 8v .
the engine in this vid is 12v
http://www.videosat.org/video/eer8FSOBslk/Monte-Carlo-MC220-Berlinette.html
www.dbsmotorsport.co.uk
getting dirty under a bus
MakeEverything
posted on 26/9/11 at 10:16 PM Reply With Quote
Ive got one sitting in my garage. The engine plate will tell you, but it looks to me like an 8V renault J7T engine. Either 2L or 2.2.
Photos of me replacing it are here;
http://www.locostbuilders.co.uk/photos.php?action=gal&user=MakeEverything&folder=21%20Turbo%20Re-Fit
[Edited on 26-9-11 by MakeEverything]
Kindest Regards,
Richard.
MakeEverything
posted on 26/9/11 at 10:20 PM Reply With Quote
No, the plate is on the RHS of the block near the water pump.
Kindest Regards,
Richard.
Trev Borg
posted on 26/9/11 at 10:31 PM Reply With Quote
Its the 2.0 8V then
so must be the J6R or J7R, as the J7T was a 2165cc.
I will have a look for a plate tomorrow.
Also I try and find out what transaxle it has. Think it will be the NG3.
Out of curiosity, are there many engines that are a straight bolt on job to replace this one?
I assume the turbo version is the same block (173 bhp)
MakeEverything
posted on 29/9/11 at 07:24 PM Reply With Quote
Originally posted by Trev Borg
Its the 2.0 8V then
The J7R and J7T both use the (J7) block. I replaced my J7T with an R and added a supercharger. Easy engine to work with and plenty of power can be had with the 2.0 J7R. Up to 320hp has been reported, but not on standard liners, which are the weakest point. Never heard of a burnt out piston or valve (8V turbo head), or broken rods before the liners go.
The reason the liners crack is the casting on cylinders 1 and 4 mean that there are flats that leave the outside of these cylinders weak.
Kindest Regards,
Richard.
Trev Borg
posted on 29/9/11 at 07:57 PM Reply With Quote
Thanks for the info. I am struggling to find out anything about the engine.
I assume that it came fuel injection, as it came from a Savanna, and I don't think they ever came with the lower power carb version.
The car was build as a hill climber originally, and had a hot cam and a set of chopped webers on an injection fuel rail, running with emerald ecu. It was producing 149bhp.
It was now been detuned for road use with a Weber 28 x 32 Dara dual barrel down draught, running the same ignition for sparks.
Trev Borg
posted on 29/9/11 at 10:08 PM Reply With Quote
Are there many other engines that would bolt direct to the gearbox?
