Author: Subject: Type 9 Gear seclection - help needed please!
adrianreeve
posted on 29/9/11 at 01:57 PM Reply With Quote
Please could someone look at the photo below and tell me the saddle clip is he right way around, and whether or not the reverse detent is correctly installed?
When I try to select first gear, I'm getting reverse. The gearbox came to me out of the car, so I've no idea if everything is where it should be!
If everything is there and in the right place, any ideas why I could be getting this problem?
http://i1234.photobucket.com/albums/ff406/adrianreeve/14591b1b.jpg
Any and all help much appreciated
Adrian
[Edited on 29/9/11 by adrianreeve]
Paul Turner
posted on 29/9/11 at 02:34 PM Reply With Quote
Both look fine to me. Has the gearlever benn modified?
adrianreeve
posted on 29/9/11 at 02:59 PM Reply With Quote
I did modify the gearlever to a quickshift by moving the shaft up the collar, spacing it out with nuts, and sawing some of the rubber away to compensate. I've now put it back to how it was, with exception of the rubber, and still the same. If anyone has a spare gearlever, I could always try that I suppose?
Adrian
snapper
posted on 29/9/11 at 05:20 PM Reply With Quote
Because it's down and across for a type 9 you probably need to space the lever a little more.
When you bolt it down you are probably exerting enough force to defeat the detent.
I eat to survive
I drink to forget
