zilspeed
posted on 6/8/04 at 09:04 PM |
Zetec Ignition
Probably should have kept this in Dave 1888s thread, but thought it was sufficiently different to warrant it's own little thread. Anyway - to
the point.
Locost Zetec Ignition
Having done a bit of reading, here is my take on the easiest and cheapest way to get sparks happening on a zetec - this is assuming you have already
bolted a set of webers or dellortos on and a suitable exhuast manifold.
1) Get a hold of an EDIS 4 module from the bulkhead of an early 90s Ford - this link shows the
pin out arrangement. Not hugely complicated.
Bear in mind that the EDIS on it's own will give you a rock steady ignition timing of 10 degress BTDC with nothing else - no advance or retard,
but enough to run your engine.
2) We now need a 'locost' ECU to plug into the EDIS and give advance retard.
To my mind, the only 'locost' solution is Mega Jolt Lite Junior
Available completely built and tested for 155 US dollars - inc delivery.
www.xe.com reckons that is £84 - wayyy cheaper than anything else.
Or buy the kit and build it yourself for 64 dollars - about 35 quid + a case.
Personally I reckon a built and tested unit for 84 quid is fantastic.
Is there a cheaper way to get a zetec up and running with 3D mapped ignition ?
Aplologies to all those who already know all of this, just thought it was relevant to bring it back to the surface :-)
dave1888
posted on 6/8/04 at 10:04 PM |
This is the route i will probably go down although I have got the DIS coil pack don't know if there's any difference between the two
mangogrooveworkshop
posted on 6/8/04 at 10:28 PM |
they have been there done that
http://www.xr2zetec.co.uk/
locost mad4x4 s site
[Edited on 7-8-04 by mangogrooveworkshop]
givemethebighammer
posted on 7/8/04 at 11:12 PM |
the http://www.zetec-cat.co.uk people
have loads on Zetecs
this is good
http://cyclops.dmu.ac.uk/tiger/paul/zetec-budget.html
Ignition taken care of by stock Ford components.
[Edited on 7/8/04 by givemethebighammer]
andyharding
posted on 9/8/04 at 09:25 AM |
I've just ordered the parts to make a MJLJ. Once I have all the bits I need I reckon it will have cost about £100.
£84 for a finished unit would be great but you're forgetting import duties.
The MJLJ is designed to use a MAP sensor which won't work if you're running twin Webers on individual manifold runners as you don't
have a common vacuum take-off. To get round this and still provide 3D ignition I'm going to modify the MJLJ to use a TPS. If this works I may
well offer fully built units complete with 3D map for the Zetec.
To start with I'm going to try and convert an Emerald map. If anyone has any Emerald or Omex maps please email me a screen dump of the map
andy.harding@evowebdesign.co.uk.
Are you a Mac user or a retard?
bob
posted on 9/8/04 at 04:54 PM |
Keep us posted on this one andy
zilspeed
posted on 9/8/04 at 05:20 PM |
Fair comment on all these points.
As regards import duty, I've been lucky so far I guess - I've imported about a dozen times now and paid duty about twice - good fortune I
suppose.
Regarding the MAP sensor - yep, agreed - a TPS has to be more suitable if using webers. However Brent himself has suggested that using a TPs as a
direct replacement is realtively simple - but I'm sure you know this anyway.
Having run an old clockwork dizzy with webers on my old triumph engined car, it was relatively simple to 'sum' the vacum takeoffs from
each individual inlet tract. This would surely work for a MAP sensor, especially if fed from a plenum to damp the effects of individual cylinders.
JF
[Edited on 9/8/04 by zilspeed]
