Trollyjack
posted on 17/11/11 at 09:56 PM |
Engine no ?
Where is the engine number on a crossflow
only one I can see os stamped on top of the cylinders
can only make out 0J01347 its a 711m engine 1.3
any one any idears
TrollyJack
spiderman
posted on 17/11/11 at 10:27 PM |
Front n/s corner of block next to no 1 cylinder. It is viewed from above and the no you have quoted looks about right mine is 2letters folowed by 5
numbers.
[Edited on 17/11/11 by spiderman]
Spider
DixieTheKid
posted on 17/11/11 at 10:30 PM |
All the cross flow blocks are the same I believe. I cant comment on where the number is tho.
COS IT'S Worth IT
posted on 18/11/11 at 08:21 PM |
Wrong, they all have the same bore size but the 1600 is approx 16mm taller than the 1100 or 1300 which share the same block
