shedman
posted on 4/12/11 at 06:20 PM |
Fitting 1600cvh to type 2 gearbox
Hi guys hope you can help me . In the summer I bought a locost with escort running gear . Now the time has come to up the power.so I bought a cvh1600
when I got it home I stripped the engine down an decided to regrind the crank an fit new shells .had the engine bored out to plus 40thou . It also has
stage 2 head and a piper285 cam .with a veriner pulley. Along with twin dellortos . Now my question to you guys is has anyone done this mod . Having
trouble with clutches if any what clutch plate can I use an do you have to change the spigot . I really don't want to go to type 9 box means a
whole lot more work an dare I say money. Any info on this would be great. Cheers.
zilspeed
posted on 4/12/11 at 06:28 PM |
You need.
Clutch plate diameter, input shaft spline dims and a QH book. Look in there with these two numbers and you'll find the plate you're
looking for. Probably a 1.6 Sierra though.
britishtrident
posted on 4/12/11 at 06:34 PM |
A 1.4 cvh flywheel should let you use the existing xflo to type2 clutch.
[/I]
shedman
posted on 4/12/11 at 07:18 PM |
Cheers guys that's a great start maybe go to dingbros an nick there qh book dose any of this mods affect the starter.
