Author: Subject: Carb fuel return?
theduck
posted on 9/12/11 at 11:18 AM Reply With Quote
Carb fuel return?
Sorry, another stupid question.
The webber that came with my car appears to have a fuel in and out, where do I connect the out to? Just T it back in to the supply going to the pump?
RichardK
posted on 9/12/11 at 11:47 AM Reply With Quote
If its a dgas you can just block it off.
R
Gallery updated 11/01/2011
theduck
posted on 9/12/11 at 12:34 PM Reply With Quote
How do I identify which one it is? There is a tag on it that says webber but nothing else made much sense to me.
You can see it in this video http://www.youtube.com/watch?v=o0xAkxbJGXA&feature=youtube_gdata_player
r1_pete
posted on 9/12/11 at 12:44 PM Reply With Quote
It doesn't matter which you use/block, they are common and before the float valve.
theduck
posted on 9/12/11 at 12:56 PM Reply With Quote
Brilliant cheers. Makes life easier then.
Dingz
posted on 9/12/11 at 01:53 PM Reply With Quote
They are not the same, at least the ones I have seen, there is a brass restrictor in the return side so that fuel doesn't wizz past the carb and not bother going in. If you connected the inlet on the return then you probably have problems with fuelling at wot. As has been said just block the return side.
went on and on.
theduck
posted on 9/12/11 at 02:02 PM Reply With Quote
Thanks dingz. If that's the case how do I identify the return side?
r1_pete
posted on 9/12/11 at 02:13 PM Reply With Quote
Appologies if I've mis informed, I can see the reasoning, I've had several DGAS' and not noticed a restrictor.
Angel Acevedo
posted on 9/12/11 at 03:25 PM Reply With Quote
Would it be a through fitting used when you install more than one carb fed by the same fuel line?
