Author: Subject: Far better without my exhaust
gaz_gaz
posted on 27/6/12 at 12:34 PM Reply With Quote
So, i done a trackday the other day and all was going very well, car felt quick, plenty of punch out the corners etc...
Just as i passed the pit entrance i heard the exhaust pop off, problem i've had a couple of times where the Akropovic titanium can slips off the link pipe,
Anyway i decided to keep at it for the 4 and a bit mile lap and the car was transformed, it felt like she was reving alot quicker and certainly felt faster?
Now i'm wondering if the Akropovic was causing a restriction or if it's all in my head?
MNR with an early carbed R1 motor,
any input from anyone?
Slater
posted on 27/6/12 at 12:50 PM Reply With Quote
Also, try removing your dampers (like Mr Whippy a few posts below) might improve things.
Although he was refering to an old Land Rover.
[Edited on 27/6/12 by Slater]
gaz_gaz
posted on 27/6/12 at 01:01 PM Reply With Quote
seems to be the way forward in these tough times....
forget buying new parts, just remove the old ones
coyoteboy
posted on 27/6/12 at 01:26 PM Reply With Quote
Most exhausts will cause some level of restriction but it's equally possible that shortening the system just changed the efficiency in the region you were using by changing resonances? Excluding the ability to use resonance effects to actively empty the cylinders, exhausts and their associated restriction are only detrimental to performance.
gaz_gaz
posted on 27/6/12 at 01:40 PM Reply With Quote
what i'm trying to determine is the best way forward...
i'd have expected the Akropovic exhaust to be upto the job but now i'm doubting it.
so
do i fit the replacement Akropovic can i already have, or I'm thinking about having Simpson Exhausts or similar make me a proper system but with that comes a fairly hefty price tag,
decisions decisions...
gaz_gaz
posted on 27/6/12 at 02:45 PM Reply With Quote
http://www.youtube.com/watch?v=g68x9jhI9KY
little video here to let you see the diff i'm talking about..
excuse the horrid lines, first time at Spa and had no idea where i was going
sounded far better with the can off at 3mins 11secs!!!
[Edited on 27/6/12 by gaz_gaz]
loggyboy
posted on 27/6/12 at 03:06 PM Reply With Quote
Sounds louder, but impossible to tell from those two laps if its faster. Theire are just too many varibles -gentle thru first few bends on out lap traffic on second lap. Cant even really string 2-3 bends together when playing the laps simultanously that dont have some sort of obvious variation.
Mistral Motorsport
mark chandler
posted on 27/6/12 at 04:51 PM Reply With Quote
You will get faster and smoother as time goes on, was the can completely open or baffled?
If baffled then expect it to be better, if straight through and the same diameter as the manifold exit then it will make little difference so in your head.
Confused but excited.
posted on 27/6/12 at 05:15 PM Reply With Quote
That's what Mr. Chapman said and he went a lot quicker.
coyoteboy
posted on 27/6/12 at 05:20 PM Reply With Quote
There's a piece of cake way to tell, assuming it's a road legal car. Take it to a car park and do a few 0-60s with a smartphone accelerometer. Average the results with and without, then leave before the plod show up.
procomp
posted on 27/6/12 at 06:52 PM Reply With Quote
Hi
There's a lot off effort to be put into a silencer design if it is to be quiet whilst not loosing power. It is something that most overlook. But on the race cars it is something we take quite seriously. even when we have a Max DB level off 105 it is hard to get a race engine down to that limit especially if running wild camshafts Etc.
In the end we found it easier to make our own rather than having to rely on others to try and supply silencers which would never work or need repacking every five minutes. Also the material used to make the silencer casing has to be selected also, Stainless is not a good material to use if trying to reduce the Db. Most off ours are made in aluminum and only contain steel for the Perf ( stainless ) and outer fixings. Also tail pipe design needs to be looked at as that's an area where you can create extra noise by being too big/bling.
Cheers Matt
