Author: Subject: Removing the remote from an LT77 gearbox
scudderfish
posted on 1/7/12 at 08:18 AM Reply With Quote
I need to disconnect my propshaft from my gearbox to get the engine out. I can't get to is from below as the exhaust is in the way and I have a morbid fear of being significantly under my car whilst applying force to it. From above, the connection is covered by the remote gearstick mount. I've disconnected the four bolts holding it to the gearbox, and I've got the lever out. However, the shaft that connects the stick to the gearbox is preventing me from getting any further. I can see a nut through a hole, but that just spins with the socket and doesn't undo. Does anybody know how to get the remote off?
DanP
posted on 1/7/12 at 09:09 AM Reply With Quote
Hi,
My memory is very hazy on this one but I think the connection was some sort of ball and socket affair, I remember using some sort of prodding device to reconnect them, try moving the gear stick and you should see it rotate and you should get a better idea of how they connect.
Sorry I can't be more helpful!
Dan
robinj66
posted on 1/7/12 at 12:49 PM Reply With Quote
here are a couple of pics which hopefully show the mechanism underneath the remote - I couldn't remember how to separate it from the gearbox so i resorted to the manual -
"remove the nut and pin which are used to connect the remote control shaft to the selector shaft"
[img][/img]
[img][/img]
robinj66
posted on 1/7/12 at 12:54 PM Reply With Quote
This pic should show the nut that you can see - it is part of the main gearbox - there shoudld be a pin underneath which needs to be removed
[img][/img]
scudderfish
posted on 1/7/12 at 12:55 PM Reply With Quote
So it looks like I need some sort of flat bladed screwdriver from the bottom....
robinj66
posted on 1/7/12 at 01:33 PM Reply With Quote
Honestly i can't remember
I'll try and have a look if I get permission to step inside the garage today
scudderfish
posted on 1/7/12 at 04:26 PM Reply With Quote
Got the bugger off. It turns out that nut is a red herring; if you lift the remote up from the rear, the selector banjo pops off the bottom
