Nickctp
posted on 2/9/12 at 08:33 PM |
Ford x flow pcv valve
Not 100% sure on whose advice to take here but lots of people say to just totally remove the pcv valve - others say its essential?? Which advice is
the best??
[Edited on 3/9/12 by Nickctp]
phil m
posted on 3/9/12 at 02:35 PM |
Only remove it if your (fitting an oil catch tank and) re plumbing the breather back into the rocker cover
This it how I did mine
Nickctp
posted on 3/9/12 at 03:03 PM |
Yep I have fitted catch tank - Was breathing far to heavy (without catch tank) but reilised this was because no catch tank fitted. So Crank case and
rocker cover to catch tank - then from catch tank to air filter or just atmosphere would you reccomend? (without PCV fitted of course).
N
phil m
posted on 6/9/12 at 04:47 PM |
Hi there
Crankcase to rocker cover, with another rocker cover out to catch tank , which is vented to atmoospher via a filter
Westy1994
posted on 7/9/12 at 04:35 AM |
Odd this subject should come up, after 4 years with the same setup and sick of having to empty the catch tank all the time, I thought I would change
the pipework around. I did have block to tank and rocker to tank ( yes I know the block one should have gone into the rocker cover first), so
before drilling more holes in the rocker box, I tried removing the rocker one altogether, just relying on the block to tank one. Bingo problem solved,
for some reason oil must have been blowing via the rocker feed and filling the tank far faster, I have done well over 200 miles and all I got out of
the tank was a teaspoon full, normally this would have been full (1ltr) in less than half those miles. I don't think I will bother with the
second hole in the rocker now.
posted on 7/9/12 at 06:57 PM |
On mine I just have a hose coming from the block adaptor straight to the catch tank with no hose from the rocker cover, it's been like that for
several years with no problem. I do have a fuel pump blanking plate with a shield on it to stop oil from going straight to the breather elbow. I have
found that not filling the sump to the max level on the dipstick helps cut down on oil consumption
