carse
posted on 14/9/12 at 04:06 PM |
Ford diff: 7.5-inch internals in 7-inch casing
Hi all,
Just wondering if the internals from a 7.5-inch Ford LSD would go into my existing 7-inch open diff. I'd prefer to find a new LSD so as not to
have to cannibalise parts (I'm not bothered about the work as I'll overhaul it before it goes in anyway) but I was just wondering if this
is theoretically possible if I have no other choice?
Sean
Xtreme Kermit
posted on 14/9/12 at 05:12 PM |
I'm guessing but I wouldnt have thought so. The 7.5" is the diameter of the crown wheel, so it's unlikely it will fit.
But, I'm sure a more knowledgable person will be along shortly...
djtom
posted on 14/9/12 at 07:05 PM |
I've never tried it, but I believe that the 7" and 7.5" measurements refer to the outer diameter of the crown wheel, so I doubt that
you'll have any luck making the larger crown wheel fit in the smaller casing.
Whether the inner diameter of the crown wheel is the same where it mounts to the diff itself I don't know, but that would allow you to swap teh
7" CW onto the 7.5"diff if so. Somehow I doubt it - that'd make it far too easy!
snapper
posted on 15/9/12 at 06:47 AM |
Won't fit.
Yes the Crown wheels are 7" or 7 1/2"
The casings are bigger for the 7 1/2" for the very reason that it's bigger, Ford won't waste money (and weight) on a bigger casing
for no reason.
The crown wheel is matched to the pinion and the pinion would also have to sit further back.
I do have a 3.62 7" LSD Lobro from a low milage Sierra 4x4 V6 estate I am happy to sell but your a long way from Essex.
[Edited on 15/9/12 by snapper]
I eat to survive
I drink to forget
carse
posted on 15/9/12 at 02:54 PM |
Snapper, I've u2u'd you. I'm actually down in Hertfordshire now, so not too far from Essex.
Carse
YODI
posted on 16/9/12 at 11:39 AM |
Sorry to hijack but is my diff a 7", it's originally from a 1.8cvh sierra 1991 car
