xico_ze54
posted on 1/10/12 at 11:15 PM |
Sierra diff identification - Help needed
hi
anybody can say to me if this Sierra diff ID seams that it has some kind of value?
83bg mc 362
4a2l17 0628
thanks
Amadeu
snapper
posted on 2/10/12 at 06:29 AM |
From the numbers I'm thinking 3.62 open diff
The most common of them all
Still has a value £50 to £80
I eat to survive
I drink to forget
Myke 2463
posted on 2/10/12 at 06:38 AM |
The important bit is 83bg mc 362
83bg = case type / 1long bolt = 7" / 2 short bolts = 7.5 diff mc = open diff 362 = 3.62 ratio
Be Lucky Mike.
xico_ze54
posted on 2/10/12 at 07:59 AM |
many thanks my friends
xico_ze54
posted on 2/10/12 at 10:08 AM |
anyway... what is considered an «open diff»? isn't that a normal diff?
Dusty
posted on 2/10/12 at 11:48 AM |
The numbers you need are on a thin ally tag which is held by one of the backplate bolts. These tags do get lost/corrode away/disappear. If you can
remove the back cover you will find the ratio written in white paint on the rim of the ring gear. You will also be able to see the type of diff.
xico_ze54
posted on 2/10/12 at 12:48 PM |
I know that part of the ali plate. but as some people refered the 'open diff' I started think if it was not a certain type of diff, but
anyway it is only a diff that was openned, right?
garybee
posted on 4/10/12 at 07:34 PM |
You were right with your first guess. An 'open' diff' is just a diff' which doesn't lock in any way, ie a normal one.
