posted on 16/12/12 at 08:57 PM |
Fitting mx5 engine in locost
Is there anyone who has fitted a mk1 mx5 engine to a locost?
Is there anything I should know or do to make it any easier to fit
Cheers Steve
JAG
posted on 17/12/12 at 11:36 AM |
Yes - I did it as has a guy called Keith who works for Flyin' Miata in the States. Search on-line for his story but he also posts on here from
time to time.
Have a look at my photo archive 1st.
Things I did to make it easier;
1) chopped large lumps off the tail of the 5 speed Mazda gearbox and created a new mounting point.
2) reduced the depth of the standard aluminium sump and added some extra volume.
3) got rid of the standard airbox and trunking to the throttle body - I made some new pipe to mount the MAF and fitted an aftermarket
'cone' shaped filter
Other than that it fitted quite well. Standard ECU and sensors etc... It's still running like this as I built a Megasquirt but haven't
fitted it yet
U2U if you need anything else.
EDIT; This is Keith Tanner of Flyin' Miata
[Edited on 17/12/12 by JAG]
Justin
iank
posted on 17/12/12 at 01:23 PM |
Seems to be out of print, so therefore silly money at the moment, but if you can track it down Keith Tanners book will be very helpful
http://www.amazon.co.uk/Build-Cheap-Sports-Motorbooks-Workshop/dp/0760322872/ref=sr_1_30?ie=UTF8&qid=1355750398&sr=8-30
Saturn Sports cars did a build manual for an MX5 version of the Haynes roadster (you don't mention which "Locost" you are planning
(Escort Mk2 based Champion version or Sierra based Gibbs version) it's still kicking about on the web as a pdf.
http://gillhamonline.co.uk/Mx-5_Build_Guide-rev3.pdf
Anonymous
chillis
posted on 17/12/12 at 02:25 PM |
A guy in New Zeland did this and had a good website on it but at the moment I can't seen to find it - maybe a google search
Never under estimate the ingenuity of an idiot!
Bare
posted on 17/12/12 at 05:25 PM |
Erm isn't that called a Haynes roadster... there's even forums for it.
