wombat
posted on 20/12/12 at 09:40 PM |
Sump Sealant
Evening, ready to fit my chopped original cast sump (thx Ian @ Flash Customs- great bit of welding).
What's the best,if any, sealant to ensure it doesn't leak???
loggyboy
posted on 20/12/12 at 09:46 PM |
Mine was steel and migged, which I water test once welded and seemed fone, but just to be sure I powdercoated it, which I think is pretty good way of
ensuring a seal.
I wouldnt want to use any 'stick on' sealant in case the oil broke the adesion and ended up with a strip of sealant being sucked round the
system
Mistral Motorsport
beaver34
posted on 20/12/12 at 09:58 PM |
normal black silicone is what i use.
alot of standard ford sump are gasketed with black silicone nothing to worry about
mark chandler
posted on 20/12/12 at 10:18 PM |
You need a special sump sealant, halfords sell good stuff made by wurth which is not stupidly expensive.
Do not use household stuff, oil will attack it ending up with a sticky leaky mess.
snapper
posted on 20/12/12 at 10:27 PM |
Use the right stuff and not to much
I had to strip an engine after the previous builder used to much grey silicone which blocked the oil pickup enough to drop oil pressure
I eat to survive
I drink to forget
blakep82
posted on 20/12/12 at 10:44 PM |
if the welding's as good as you say, it won't need sealing
personally i wouldn't put anything inside it, maybe a good few coats of thick strong paint on the outside, and if you see any oil drips on your
garage floor, then check it out
________________________
loggyboy
posted on 20/12/12 at 10:54 PM |
THeres a difference between sealing a sump gasket and sealing the welded edges at the base.
Mistral Motorsport
Craigorypeck
posted on 20/12/12 at 11:31 PM |
IF its a gasket sealant.... loctite 5910
wombat
posted on 21/12/12 at 07:24 AM |
Sorry I was not clear, I meant gasket sealant.
Thx for replies so far.
Paul Turner
posted on 21/12/12 at 09:12 AM |
If its a silvertop sump you only need the specific Ford gasket (don't buy cheap pattern ones, the material goes soft when oil touches it) with 4
small blobs of suitable sealant at the points wehre the front and rear covers bolt to the block, there is a small step and the sealant ensures there
are no leaks.
If its a blacktop the aluminium section requires Ford gasket with the 4 blobs of sealant but for the joint where the steel section bolts to alloy
section there is a correct Ford spec sealant.
Do it once and do it right, its far easier out of the car.
