Author: Subject: Modified Type 9
ludsonline
posted on 3/4/13 at 06:04 PM Reply With Quote
Modified Type 9
Hi,
Has anybody modified a 2.8 Type 9 to a standard Type 9?..
Paul
cliftyhanger
posted on 3/4/13 at 06:17 PM Reply With Quote
As in machined the first motion shaft?? I had a chap do mine. The shaft obviously needs to come out of the box first.....
However, I believe it is possible todo it with a grinder. Not as neat as a lathe of course
mookaloid
posted on 3/4/13 at 06:20 PM Reply With Quote
I've modified one using a spacer between the bellhousing and box from Caterham - works really well and it means that you don't have to cowboy the input shaft
ludsonline
posted on 3/4/13 at 06:50 PM Reply With Quote
I've got access to a lathe at work & got all the dimensions. Would be cheaper to the mod than the spacer job ...
snapper
posted on 3/4/13 at 07:28 PM Reply With Quote
Moves the engine and bell housing about 25mm forward but a basic, easy job
I eat to survive
I drink to forget
