Author: Subject: type 9 rear oil seal - output shaft end
AndyW
posted on 23/8/13 at 12:24 PM Reply With Quote
Following on from my small and decent iva fail, I need to look at why my gearbox decided that the oil should be on the outside and all down the tunnel.
I take it there is an output shaft oil seal, but is it an easy fix from within the tunnel? or box out.
I need to book my iva re-test and must have this done as don't want to go back with more problems.
Any advice very welcome.
Ta
adithorp
posted on 23/8/13 at 12:37 PM Reply With Quote
You should just need the prop out then prise the old seal out with a screw-driver. The new one should just press in. A large socket or simlar of a diameter close to that of the seal should help push it in. Put a smear of grease on the edge to help it go in and around the seal lip to lubricat the shaft when it goes back. Be careful to keep it square to the hole and not cocked over.
http://jpsc.org.uk/forum/
steve m
posted on 23/8/13 at 01:08 PM Reply With Quote
Before replacing the seal, have you checked the oil level in the gearbox, as it could of been overfilled
and just pumped out the excess?
AndyW
posted on 23/8/13 at 01:44 PM Reply With Quote
I will check this first, I filled it so that I just got a trickle out of the plug and it took a litre. It did spit out a load
Paul Turner
posted on 23/8/13 at 02:45 PM Reply With Quote
Are you sure the leak is from the output shaft seal. The oil level in the box is well below this seal, the bush just in front of the seal relies simply on a little splash for lubrication and there are channels to return the small amount of oil to the box.
britishtrident
posted on 23/8/13 at 03:18 PM Reply With Quote
On the Sierra 5 speed the level plug isn't really a level plug it is only a filler plug the oil level should be about 25mm/1"/thumb's width lower and the car must be level, but it sounds like the seal is knackered.
[/I]
Paul Turner
posted on 23/8/13 at 04:13 PM Reply With Quote
Wrong. That may have been the case with the early boxes but Ford lowered the plug in about 1985 to prevent overfilling and the problems it was causing. In these later boxes you fill until it runs from the plug but in my Seven with the engine/gearbox alignment I can never get the full amount in Ford specifies. In the 15 years or so I have been using type 9's never had an issue.
AndyW
posted on 23/8/13 at 08:58 PM Reply With Quote
OK So,
How easy is it to change and WHAT IS THAT CORRECT OIL LEVEL for a type 9 5 sp please!!!
David Jenkins
posted on 23/8/13 at 09:21 PM Reply With Quote
I couldn't get a sensible answer to the question of oil level and the filler hole, so I took the lid off the box, sucked all the oil out, and replaced it with the correct amount of oil (I was changing the oil anyway). The box doesn't have a drain plug, which is why I'd sucked the oil out with a gadget I'd bought on ebay (looks like a big syringe).
At the same time I modified the lid by adding a brass filler hole, and made a dipstick to match. The dipstick isn't a permanent fitting, I just take out the plug and insert the dipstick (on which I'd marked the correct level just after I'd filled it with the correct quantity of oil. The reason for adding the filler hole in the lid is that it's impossible to get to the original filler hole when the gearbox is in the car.
As for the rear seal - it easy to fit, quite cheap, so if you have doubts then it makes sense to replace it. Just take care when you re-fit the prop shaft - lots of oil on the shaft end (oooer!) and make sure it goes in straight (oooer again!).
AndyW
posted on 24/8/13 at 08:06 AM Reply With Quote
Thanks David,
I'm going to fit a new seal anyway just to be safe. Problem is I don't know how much oil is in there now and getting to the top of the box will be some major taking apart.
I will pop into Burton Power in the week and ask them about oil level and see what they say, got my IVA re-test next week and want it sorted by then!
