Barkalarr
posted on 27/8/13 at 10:19 PM |
Which Engine ?
Which CEC is today's most desirable engine technology for a se7en and what year donor car is it coming out of?
It needs to connect to a type 9 gearbox.
I notice the newer Catering Vans seem to have a Ford Sigma engine (Zetec-SE)
Sigma engine seem to have been superseded (according to Wikipedia - so it must be true) by the ecoboost technology. Isn't this going to be too
tall for a se7en?
What direction would the collective take?
Volvorsport
posted on 27/8/13 at 10:29 PM |
VW Tsi ...
but i think in the case of a seven youve just described a 2.5 millington....
www.dbsmotorsport.co.uk
getting dirty under a bus
ste
posted on 27/8/13 at 10:36 PM |
I went for a Sigma engine.
The 1.7 VVT from the Puma.
Reasons; light weight, all aluminium (2/3 the weight of a black-top zetec)
125bhp standard, can be turbo'd to 240bhp on standard internals and injectors. Down side is you need to have the crank drilled out to take a
spigot bearing for the type 9. You need an adaptor bell-housing and ideally hydraulic clutch release.
The vvt can be controlled by an aftermarket ecu and gives more low down torque and more top end bhp.
I think the two best engines are a corsa vxr engine. 1.6 turbo and 200bhp. can be bolted to a type 9 with a normal redtop bell housing adaptor. And
then a honda s2000 engine and box
loggyboy
posted on 27/8/13 at 10:38 PM |
Zetec will be the prime engine for type 9 mounting for next 5 yrs imo, till the ecoboost is explored. Especially as crate lumps are still available at
circa £700.
As for general donors, mx5 and to a lesser extent the bmw will be the more modern replacement as ford rwds parts become more scarce and manufacturers
explore (as some already have) newer avenues.
Mistral Motorsport
eddie99
posted on 27/8/13 at 10:40 PM |
1.6 ecoboost, cheap (admittedly not zetec money but cheap considering brand new 2013 engine), readily available. 215bhp standard with aftermarket ecu
and wiring.
http://www.elitemotorsporteng.co.uk/
Twitter: @Elitemotoreng
Facebook: http://www.facebook.com/pages/Elite-Motorsport-Engineering/153409081394323
ste
posted on 28/8/13 at 12:53 AM |
If you're talking future, I'd like to install a Tesla rear axle and then fill the engine bay with lithium batteries. 415bhp and loads of
torque
daniel mason
posted on 28/8/13 at 06:20 AM |
i dont think a turbo is the way forward at all. i remember watching a 5th gear with plato driving the new wesfield with the 1.6 turbo lump from the
vxr and he hated its power delivery!
id agree with loggy and say a 2.0 zetec. tb's and cams should see plenty of power for a 7!
dhutch
posted on 28/8/13 at 07:09 AM |
quote: Originally posted by daniel mason2.0 zetec. tb's and cams
Rightly or wrongly, you certainly wouldnt be the first to use this combination!
cliftyhanger
posted on 28/8/13 at 09:11 AM |
so why isn't the duratec 2.0 so poular? after all zetec donors are all 12+ years old (or is it more)
OK, needs a new bellhousing, but surely using the later engine is long term a better idea. Saying that the smaller all alloy zetecs are a good little
engine and have a definate weight advantage.
Still, I like the zetecs, but think things will change on that front. Especially as type 9's are getting harder to find. So maybe the future is
german or japanese.
loggyboy
posted on 28/8/13 at 09:27 AM |
It is realatively, but on a budget, the engine cost premium (at the mo, as that will come down) combined with the bellhousing cost makes it less
attractive for only a few extra HP.
Availablity of super cheap used and cheapish crate zetecs (which makes a new reg quite accesable) keeps them at the top of the list.
The other reason zetecs seem more popular is its an easy conversion from older fords, whilst the duratec exhaust maybe on the same as the pintos, the
'bolt on' gearbox makes the zetec a good 'refresh' choice.
Mistral Motorsport
ali f27
posted on 28/8/13 at 09:43 AM |
Have a ride out in sombodys duratec car end of story
dhutch
posted on 28/8/13 at 04:19 PM |
They are becoming more common, but while other may disagree or add to the list:
- They cost more, both new, and used.
- They need a bespoke bellhousing, as they do not use a ford bolt pattern.
- The weight/power difference is fairly limited
- The aftermarket market is still smaller
- The exhaust is on the wrong side.
Basically, while slightly more modern, most of the changes are in the bits we dont use, at which point there limited advantage, and several
disadvantages.
The sigma 'zetec' is more different, or atleast as diffrent, to the zetec as the duratech.
Daniel
Nitrogeno25
posted on 28/8/13 at 04:43 PM |
+1
ali f27
posted on 28/8/13 at 05:03 PM |
Time for a proper answer decide what you most want and balance that with what you can afford under 200 bhp pinto great engine loved mine still got it
probs never sell cvh again good engine old 16 valve ford ie good engine lot of nutsack talked we had 200 bhp with out a lot of money spent zetec
good engine cheap new in a box all go on ford gearbox.
Up the budget £300 and change bellhousing clutch etc and you can bolt lots of things to ford gearbox, redtop great engine as heavy as the above but
over 200 bhp, duratec all alloy over 200 bhp not difficult at all next lightest to bec going to be in plenty full supply mondeo all these are 2.0.but
same applies to zetec se .
When we build a seven power to wheight seems to be the name of the game thats why a 128 bhp blade car gos so well.
I f you see your self racing it ever build the lightest car with the most power you can affford at the start with the flexibilty to tune
afterwards.
All of us would have a nice garage if we won the lottery mine would include V8 DAX for sunday runs but i would keep the f27 duratec for the times when
i wanted to go fast and fritghten myself
So best power to weight engine standing out of the car has to be target
Comments welcome Ali
dhutch
posted on 28/8/13 at 05:34 PM |
Time for a proper answer.
Decide what you most want and balance that with what you can afford.
Under 200 bhp:
Pinto; great engine loved mine still got it probs never sell
CVH; again good engine old 16 valve ford ie good engine lot of nutsack talked we had 200 bhp with out a lot of money spent.
Zetec; good engine cheap new in a box all go on ford gearbox.
Redtop great engine as heavy as the above but over 200 bhp
Duratec all alloy over 200 bhp not difficult at all next lightest to bec going to be in plentiful supply mondeo all these are 2.0 but same applies to
zetec se.
When we build a seven power to weight seems to be the name of the game that's why a 128 bhp blade car goes so well.
If you see your self racing it ever build the lightest car with the most power you can afford at the start with the flexibility to tune afterwards.
All of us would have a nice garage if we won the lottery mine would include V8 DAX for Sunday runs but I would keep the F27 Duratec for the times when
I wanted to go fast and frighten myself.
Your right that the budget and end use are important, there is no one right answer even when that's answered, but if its not, there's even
more answers.
Daniel
posted on 28/8/13 at 05:58 PM |
Audi or lexus v8
DIY Si
posted on 30/8/13 at 07:46 AM |
Why does it have to bolt the increasingly hard to find type 9? The early MX-5 box is £50-100 on Ebay and will handle more power whilst having an alloy
casing so it's lighter too. And if you use the newer version, along with the VVC version of the duratec that it bolts to you have the best of
both worlds.
Sun Tzu, The Art of War
dhutch
posted on 31/8/13 at 05:59 PM |
Also valid, I knew the duratech as a mazda/ford colab using a masda volt pattern but didnt know it was that simply to mate a duratech to a mx5 box,
certainly appears to be more common to use a custom bellhousing a mate it a t9?
franky
posted on 31/8/13 at 07:32 PM |
bmw engine 4 or 6 cylinder, made for RWD, cheap to buy, runs off the standard ecu and isn't another ford.
If you do fit a ford engine remember to fit some team dynamics too
Furyous
posted on 1/9/13 at 09:26 PM |
I'm using an MX5 gearbox with my Duratec. You just need to use the MX5 starter/clutch/flywheel but apart from that it just bolts straight to the
engine. Same spigot bearing as the T9 as well. The gear changes on the MX5 box are so much better. It has a nice, definitive click-clack movement as
opposed to the T9's wibble-squidge. The main downside is it's a bit fatter than the T9 and the bell housing is bigger (Read: lower to the
ground) than the aftermarket T9 bell housings.
I got my 5 speed for £125 but they seem to normally go for around £400, which is quite a bit more than a T9 bell housing. Although, if you already
have a T9 you could sell it on and the cost difference won't be far off. The MX5 box also uses a different prop shaft yoke to the T9, which is
something to consider if you're replacing bits rather than starting fresh.
loggyboy
posted on 1/9/13 at 10:28 PM |
Under 200 bhp:
zetec se.
more answers.
Daniel
Thanks for that, was scratching my head for ages! The proper answer (allegedly), but so badly punctuated!
Also since when was the cvh 16v. Or good?
Mistral Motorsport
dave r
posted on 2/9/13 at 05:45 AM |
+1
and another
I'd love to give my imaginary friend a great big hug,
but this jacket makes it impossible.
