Author: Subject: locost fireblade help!
rob.d
posted on 1/10/13 at 09:03 PM Reply With Quote
Hi all
im looking into building a locost powered by a bike engine probably fireblade with the view to race it in the rgb class (when its finished)!.does anyone know what ratio diff is best for one of these engines or will a standard ford sierra one be suitable.also any ideas for fitting a reverse gear cheers rob.d
jossey
posted on 2/10/13 at 05:16 AM Reply With Quote
3.18 or 3.38 would be ok.
Try this and see what you want.
http://www.gamlin.org.uk/Downloads/bike_ratios.xls
David Johnson
MK9R
posted on 2/10/13 at 10:12 AM Reply With Quote
Originally posted by rob.d
Hi all
3.38 if its Indy suspension or 3.54 if its live axle. If you don't want the hassle of building the car, my fury is for sale ;-)
Cheers Austen
RGB car number 9
www.austengreenway.co.uk
www.trackace.co.uk
MK9R
posted on 2/10/13 at 10:15 AM Reply With Quote
Reverse gear - standard reduction type starter motor (I used a Honda civic one), if its live axle then you mount the gear on the engine end or the middle of the prop (like I have check out my website) or if its Indy, then mount gear direct to rear diff input flange
Cheers Austen
RGB car number 9
www.trackace.co.uk
rob.d
posted on 2/10/13 at 07:52 PM Reply With Quote
thanks for your help guys will try build with 3.38 as suggested ive been racing and building karts for last 20 years so looking forward to the change to cars, steep learning curve ahead!
