Author: Subject: Automatic Zetec
pekwah1
posted on 28/10/13 at 01:00 PM Reply With Quote
Automatic Zetec
Hi Guys,
Looking into options for engine upgrades, i'm planning on going the Zetec route for my first go.
I'm looking to buy a complete car (mondeo/focus), but was just wondering if it makes any real difference if i buy a manual or auto car? I will be mating to a 5 speed type 9.
loggyboy
posted on 28/10/13 at 01:52 PM Reply With Quote
AFAIK engines are identical, and assuming you will be changing flywheel/clutch/starter arrangement to suit type9, you should be free to choose any.
Mistral Motorsport
Charlie_Zetec
posted on 28/10/13 at 02:00 PM Reply With Quote
If the zetec is from an automatic car then the housing for the crank position sensor needs changing the manual engined type. But the sensor itself is the same for either engine.
Paul Turner
posted on 28/10/13 at 02:02 PM Reply With Quote
Obviously you will need a flywheel, and clutch but it does give you the chance to buy a proper steel flywheel instead of having your standard boat anchor modified into a deadly weapon.
Also you will need a crank sensor carrier from a manual, if you leave the auto one in it will be too short with the manual flywheel to get a signal and the car will be a no go. It cannot be changed once the engine and box are mated and in the car.
steve m
posted on 28/10/13 at 02:59 PM Reply With Quote
What about the spigot bearing ?
as I believe that some cars with auto box's don't even have a hole in the crank for a spigot bearing, as its not needed
Paul Turner
posted on 28/10/13 at 03:15 PM Reply With Quote
Had 2 Silvertops, one was an Auto and one a Manual. Both had the same crank and both required spigot bearings to be fitted. cannot imagine Ford fitting a different crank, simply complicates manufacturing.
steve m
posted on 28/10/13 at 07:05 PM Reply With Quote
That's fine, just making sure my m8 doesn't get lumbered with some pig iron
FWI on automatic classic mini's, the engine is different, and does not have a spigot bearing,or even a hole to put one in or a dip stick hole on the engine
hence my question
steve
austin man
posted on 28/10/13 at 08:48 PM Reply With Quote
Automatic silvertop Mondeos had the EDIS 4 fitted as used in the Megasquirst set up
prawnabie
posted on 28/10/13 at 08:49 PM Reply With Quote
I see from your other post you are intending on using the stock ECU? It that case check to make sure the electronics are the same between the two transmissions.
Shaun
