Fant
posted on 14/6/14 at 01:07 PM |
T9 input shaft bearing
Hi,
I want to replace the input shaft bearing on my T9. According to the Ford drawings I just have to remove one circlip from the shaft and the bearing
will just come off.
Is it really that simple or do I have to disassemble the gearbox further? Is the bearing shrunk onto the shaft or is it a loose fit?
Thanks,
Fant
plutos3
posted on 14/6/14 at 06:04 PM |
Yes you will have to strip the gearbox as it is a press fit onto the input shaft and the input shaft cant be removed without takeing the gearbox
apart.
Fant
posted on 14/6/14 at 06:45 PM |
Thanks.
