Miks15
posted on 29/6/14 at 05:14 PM |
Engine Honing Advice
Hi All,
Got to the stage of my motorbike build where I'm doing the final bits to the engine before rebuild.
Its a 70's CB360 engine, and I'm looking to get the cylinders honed for my new rings.
Is this something I can do fairly easily myself in a vice with a drill and hone? Or should it be something I get done properly?
Can anyone recommend what tools I would need to do it myself?
Alternatively and recommendations for machine shops in the west midlands (I'm based in Leamington Spa) that can do the work and what sort of
price I'm looking at for 2 cylinders?
cliftyhanger
posted on 29/6/14 at 05:28 PM |
I have done a few engines with a borrowed tool and a battery drill. About 20 seconds a cylinder with a squirt of WD40, keeping it going up and
down.
You can get a large flapwheel type, I used this type
http://www.google.co.uk/imgres?imgurl=http%3A%2F%2Fstatic.summitracing.com%2Fglobal%2Fimages%2Fmediasite%2Flores%2FBRH-GBD41432_cp.jpg&imgrefurl=h
ttp%3A%2F%2Fwww.summitracing.com%2Fnewproductsandmedia%2Fnewproductreleases%2Fbrush-research-gbd-flex-hone-tools-now-available-at-summit-racing&h=
394&w=600&tbnid=CfrG61gpqVU_bM%3A&zoom=1&docid=uXiFRWh7hYnQzM&ei=20qwU7qCI4nuOZTGgYgI&tbm=isch&ved=0CFIQMygoMCg&iact=r
c&uact=3&dur=2407&page=3&start=39&ndsp=21
I don't like the look of the ones with 3 flat stones, not sure why.....
Saying that, if you can't borrow a tool, it may be cost effective to get it done.
mark chandler
posted on 29/6/14 at 07:11 PM |
If you are just breaking the glaze on the bores I would just use a bit if wet and dry, do not go up and down circular sweeps required.
You can get honing tools, three sprung legs with cutting stones that you just whizz around in a drill and drag up and down the bores.
snapper
posted on 30/6/14 at 04:51 AM |
I did this yesterday
3 leg hone, you should use corded drill, live the bores, don't stop drill in the bore pull it out spinning
YouTube video to see how it's done.
Took more than 20 seconds a bore to get the marks out and produce fine hone pattern.
Hone rotation for final passes is slower than you thing
Up & down movement faster
Biggest issue is cleaning the bore out after, fine metal and stone grit, my parts washer pump died so cloth and oil, then thinners ( I had tins of
spray electrical safety cleaner ) then my lateral thinking solution of a suit lint roller, over and over again, black with metal and stone, changing
sheet for every bore until it became clear, at this point it stuck to the bore wall, thinners to remove glue, final check with hand,use sheet of
sticky in hand as a tack rag if required, more thinners until clear.
Bore goes from dull to bright as stone and metal dust removed.
Oil the bores prepare to gap new rings and check piston slap.
Job done.
I eat to survive
I drink to forget
Miks15
posted on 30/6/14 at 07:47 AM |
Cheers for the advice guys,
Will be giving this a go myself then over the next week!
