posted on 28/8/14 at 08:32 PM |
Starting Engine After Long Lay-Up...
I recently bought a 2007 Ducati which had been laid-up for over 3 years due to an electrical issue.
I just about have all the problem corrected (and service items replaced), so will be looking to fire it up for the first time in a long time soon.
How best to go about it?
Remove the plugs, squirt some oil down into the cylinders, and then turn it over on the starter for a few rotations? Or am I worrying too much...
just hit the red button and hope for the best?
It's Evolution Baby!
redturner
posted on 28/8/14 at 08:40 PM |
Remove plugs to reduce the load, crank over to get some oil pumping round the internals, refit plugs and press the go button.....
big_wasa
I would pull the plugs and fuel pump fuse and spin it over in short bursts until the oil pressure builds. That should about do it
posted on 28/8/14 at 08:41 PM |
Cheers... makes sense.
mookaloid
posted on 28/8/14 at 09:36 PM |
mmmm jealous
posted on 28/8/14 at 09:44 PM |
Wheels244
posted on 28/8/14 at 10:24 PM |
1st dibs when you sell it Scootz
Serious depending on price
Build Blog: http://wheels244.wordpress.com/
drt
posted on 28/8/14 at 11:54 PM |
After standing that long I believe
timing belts should be changed
And valve clearance...
both a very hard job, with special tools.
but if you can and do, don't hesitate to post a few pics...
David Jenkins
posted on 29/8/14 at 07:42 AM |
I'd be tempted to take the plugs out and turn it over with the kick-starter first, just to get things moving. If it has a kick-starter, of
course...
[Edited on 29/8/14 by David Jenkins]
hkp57
posted on 29/8/14 at 08:02 AM |
I am another for being careful with the timing belt, Ducati says 2 years they should be changed.
At least check it for cracks or signs of hardening, if it look ok should be fine for a quick start to see if its running OK.
I would change the belts before putting any loads through it on the road, cheap insurance for an expensive engine.
[Edited on 29/8/14 by hkp57]
Fleet
SKC Raptor R - Hayabusa
Toyota C-HR Hybrid Limited Edition
Honda VFR1200 CrossTourer
DCT
Marlin Roadster 1800
Mercedes Vito 116 Sport
posted on 29/8/14 at 09:47 AM |
Belts have been changed and clearances checked.
drt
posted on 1/9/14 at 02:05 AM |
Top man
