jacko
posted on 2/1/15 at 07:40 PM |
Type 9 removal
Hi All
Has anyone removed a type 9 from a MK Indy from under the car and left the engine in place ?
Jacko
posted on 2/1/15 at 09:29 PM |
Not unless the gearbox support member is removable?
Mostna welded solid to the chassis.
Ben_Copeland
posted on 2/1/15 at 10:36 PM |
I can just about her mine out.
Remove prop and it can slide into the trans tunnel a little just enough to give it space to drop out the clutch. Mk's are not much different to
the Haynes.
It all depends how far back your engine is and how tight everything is.
[Edited on 2/1/15 by Ben_Copeland]
Ben
Locost Map on Google Maps
Roadster
Enter Your Details Here
