itsawindupuk
posted on 14/2/15 at 10:22 PM |
duratec piston to valve clearances
Hi everyone. I'm at the stage where the engine is coming along and I've been checking valve clearances. I'm using kent cams dtec 35
cams, cosworth forged pistons with pockets. I did the clay/ blue tack test and I got 1mm clearance on the intake and 0.75mm on exhaust. Is this too
close as I can't find any figures for what it should be
Nickp
posted on 15/2/15 at 07:21 AM |
They're too tight IMO especially on the exhaust side, I reckon you should be aiming for upwards of 2mm. Kent cams should be able to advise you
on this though, but I'd be having the piston pocket machined (like I've just done on my Lancia twin cam). You may get away with it, but
any over rev of slightest of valve float and they'll be hitting
[Edited on 15/2/15 by Nickp]
Nickp
posted on 15/2/15 at 07:22 AM |
Not many places will take on piston machining but there's a good place local to me that will and they do all Guy Crofts work, and he's a
perfectionist
itsawindupuk
posted on 15/2/15 at 08:42 AM |
If you don't mind me asking what sort of cost is involved with machining pistons?
mackei23b
posted on 15/2/15 at 08:47 AM |
Found this from wiseco.com
When assembling your 4-cycle engine, it is sometimes important to verify that you have adequate clearance from the piston to the valves. If you are
installing an aftermarket racing camshaft, this becomes even more important to measure. The usual rule of thumb for piston to valve clearance is .080
intake side, and .100 exhaust side. These are relatively safe values that apply to most any engine. Some engine builders may cheat these values
down to .060 intake and .080 exhaust, and Wiseco recommends discussing these lesser values with your camshaft supplier.
Ian
Nickp
posted on 15/2/15 at 09:10 AM |
I think they charged me about £20 per piston IIRC, but that was for 8 'cuts' for my 8 valve engine so yours may be double that I guess?
You'd need to centre pop all 16 valve centres into the piston tops down the valve guides for them to use as a reference point to do the
machining. Have you checked the radial v-p clearances too? To allow for the pistons and valves 'rocking'?
mark chandler
posted on 15/2/15 at 10:06 AM |
Or use the lowcost method I deployed
Get hold of an old inlet valve and turn into a fly cutter.
Grind a cutting edge on the old valve and pop into the exhaust guide on no1
Turn the engine so no1 is at TDC and lock the engine.
Run grease around the edge of the piston, loosely bolt the head onto the engine.
Push the valve down so it contacts the piston and twiddly around until it is at it deepest point in and measure from valve stem top to guide top with
a vernier
Now carefully spin the 'valve cutter' down to the clearance you want, I used a little cordless drill going gently and measuring.
Pull out and repeat on the other three cylinders.
For the inlet weld a bit of steel on the outside of the inlet and grind into a cutter.
This gives you a precise port in the Pistons aligned to the valve guides as the head is the jig, with side clearance depending on how wide you make
you valve fly cutter.
It takes a couple of hours and saves you having to dismantle your engine.
The grease keeps the swarf from going down by the pistons, if you strap a vacumm cleaner to the port most of the cuttings will get sucked out as you
go.
Regards Mark
[Edited on 15/2/15 by mark chandler]
Nickp
posted on 15/2/15 at 10:10 AM |
He may be reluctant to use that method on new forged Cosworth pistons
mark chandler
posted on 15/2/15 at 01:18 PM |
That's true, however what I have described will if done correctly give you very precise pockets that are exactly matched to the engine, this
then allows for piston/conrod piston length, crank throw and any misalignment with the valve positioning.
snapper
posted on 15/2/15 at 01:35 PM |
Has the cam been timed in or are these valves open Pistons at TDC
Inlet should be closing although not fully closed at TDC exhaust could be opening but not fully at TDC
I eat to survive
I drink to forget
itsawindupuk
posted on 15/2/15 at 04:06 PM |
basically the cams are fully timed on the verniers. Looking at the head, it sits a whole 1mm lower than the timing cover!! looks like it was skimmed
too, or maybe by previous owner or before that. So now I need another head grrrrrrr! Im running out of money! The cams have 11.3mm lift.
DIY Si
posted on 15/2/15 at 04:08 PM |
Is there a thicker, maybe turbo biased, head gasket you could use? That could get you most of a mm back, if they exist.
Let your plans be dark and as impenetratable as night, and when you move, fall like a thunderbolt.
Sun Tzu, The Art of War
Nickp
posted on 15/2/15 at 04:30 PM |
Well at least the v-p clearances should be better if you get a head with more 'meat' on it
