Author: Subject: Fiat punto 2002 1.2 16valve problem. Help)
madteg
posted on 15/3/15 at 09:08 PM Reply With Quote
Car will tick over but will not rev, its just like the throttle cable has snapped. But it is fly by wire so any ideas where I should start.
hizzi
posted on 15/3/15 at 09:35 PM Reply With Quote
think you will need the codes read before going any further,
try unplugging the maf sensor at the air filter, some cars limp if this is faulty, other wise is the fuel filter ok? but i would expect rough running rather than no revs at all
DW100
posted on 16/3/15 at 10:40 AM Reply With Quote
Plug it in, check for faults codes, look at live data for throttle pedal and throttle body position.
