Author: Subject: Pinto electronic ignition
bumpy
posted on 25/3/15 at 03:52 PM Reply With Quote
Hi
At present I have the 2 litre engine fitted with DFTH carb and an ESC2 brain. This brain is fed by signals from both the stepper motor on the carb and at least one temp sensor on the manifold.
I wish to change the carb to a 32/36 Weber which requires a change of inlet manifold as well.
Can I continue to use the ESC2 brain or will it have a mental breakdown without signals from the stepper motor and temp sensor?
Has anybody actually done this?
[Edited on 25/3/15 by bumpy]
