Author: Subject: S2000 again!
dilley
posted on 17/6/15 at 04:11 PM Reply With Quote
S2000 again!
Has anyone successfully shortened and baffled a standard sump? From what I can make out there is only 30mm between the zetec engine and the s2000 on standard sumps. I'm going to be running a modified type 9 with the s2000. How much height can I gain with the mk bonnet with a bulge?
INDY BIRD
posted on 17/6/15 at 05:09 PM Reply With Quote
some info here on sumps and contact for dry sumps, etc,
Also ref the bell housing how low that fits?
but if you go type 9 you should be ok,
Mk Steve fits easy under the scoop but not a huge amount of ground clearance,
link
http://www.locostbuilders.co.uk/forum/2/viewthread.php?tid=103603&page=2
INDY BIRD
posted on 17/6/15 at 05:18 PM Reply With Quote
Some good info here too,
ref throttle bodies how it enables to raise the engine slightly for clearences etc
link
http://forum.wscc.co.uk/forum/index.php/topic/92278-build-using-honda-s2000/
