Author: Subject: Megajolt with zetec standard efi
rich201283
posted on 6/12/04 at 10:51 AM Reply With Quote
Can i use the standard efi system with the mega jolt ignition or will i need something to control the injetion of fuel or is it injected a constant pressure
zilspeed
posted on 6/12/04 at 11:04 AM Reply With Quote
I believe the thing to do here is to keep all of the hardware except the ECU and then control fuel and sparks from a Megasquirt n edis.
The standard ford brain would have a hissy fit if you wanted it to get on with a MJLJ.
