Avoneer
posted on 6/12/04 at 10:45 PM |
My 2ltr Pinto
Isn't she lovely.
Guess I'm just bored,
Pat...
Benzine
posted on 6/12/04 at 11:47 PM |
posted on 7/12/04 at 12:34 AM |
If you're bored get the paintbrush out Pat. That bottom pulley's a bit rusty
andyace
posted on 7/12/04 at 12:45 PM |
It also seems to be missing the rest of the car!
Dale
posted on 7/12/04 at 01:26 PM |
Quite similar to our pinto engine cept 2.3l built in lima Ohio. I must admit i like the intakes on yours.
Dale
andrew.carwithen
posted on 7/12/04 at 07:02 PM |
Pat, did you use the original tube when you moved the oil filler to the rear of the rocker cover, or, (more likely) source a longer piece of tubing of
same dia?
If so, what did you use?
I was thinking, perhaps, of trying to find a bit of exhaust pipe of same dia (36mm).
Why's the engine out of the car?
If you're changing for a different powerplant you could sell me your modded rocker cover!
Andy.
Volvorsport
posted on 7/12/04 at 07:59 PM |
bah , im just thinking of all those loverly hp youre giving away to a volvo engine , brrrr
indykid
posted on 8/12/04 at 10:01 AM |
whats the erm, how do i put it, brace (bit of steel strip above idler pulley) across your timing belt for pat?
tom
Avoneer
posted on 8/12/04 at 12:01 PM |
Engine having an overhall and repaint.
Oil filler neck athe original one welded in to a piece of scaff bar!
Brace bit is a bit of a partial cover for the timing belt to keep it in place nad stop the top hose hitting it.
Pat...
