Author: Subject: Zetec Install question ( yet again!!! )
saigonij
posted on 13/12/04 at 11:34 PM Reply With Quote
All,
I have a question about which clutch to use with th e 1.8 zetec and a MT75 gearbox.
When we pulled the 1.8 out of the Orion, it fitted first time over the splines of the MT75. We then decided to order a new clutch, so we got an escort ( apparently, according to the motor factors, the orion never had the zetec... ) 1.8 but the drive plate spline hole was too small.
Can someone give me a definitive answer to this. what clutch components do i need?
thanks
givemethebighammer
posted on 13/12/04 at 11:50 PM Reply With Quote
download QH clutch catalogue:
http://www2.qha.com/catalogues/QH08.pdf
You should be able to check number of splines and match plates to covers and release bearings.
I did zetec to type nine and used mondeo cover and plate and capri release bearing.
plus this is useful:
http://www.gibbs111.fsnet.co.uk/eng_gear_comb.htm
britishtrident
posted on 13/12/04 at 11:52 PM Reply With Quote
Seem to be a number of ways of doing this combo --- this url gives info on using a FWD stryle clutch rather than going the Sierra clutch route.
http://www.classicfords.net/modules.php?name=Forums&file=viewtopic&t=811
