Schrodinger
| posted on 14/5/16 at 02:22 PM |
Zetec Silvertop to Blacktop
I have recently acquired a part built stylus with a silvertop Zetec, which has a Raceline sump, water rail and Weber Alpha ecu/throttle bodies. I am
thinking of swapping the engine for a new Blacktop. Will the Raceline sump fit ? I'm sure the water rail will but think the ecu will need
reprogramming. Am I right in my thoughts?
Keith
Aviemore
Ugg10
| posted on 14/5/16 at 02:30 PM |
Remember there are only a few authorised alpha re-programmers about, not something you can do your self or at any old dyno. Why do you want to swap,
silvertop is still a very good engine and the black top does not give you that much extra. I know the oem sumps are different silvertop is a one piece
and blacktop is a two piece. Give raceline a call.
1968 Ford Anglia 105e, 1.7 Zetec SE, Mk2 Escort Workd Cup front end, 5 link rear
Build Blog - http://Anglia1968.weebly.com
Schrodinger
| posted on 14/5/16 at 03:05 PM |
My reason for swapping is that with a new engine I should be able to get a new registration and I am not worried about emissions come mot time as they
will be the same as iva which I will have to pass. I know the webcon system is limited to certain dealers, I was just checking to see if anybody knows
for certain if it needs changing if going from silver to blacktop.
Keith
Aviemore
madteg
| posted on 14/5/16 at 07:02 PM |
Yes it will fit but you will have to swap pick up pipe as well, i fitted my silver top to my black top
britishtrident
| posted on 15/5/16 at 01:11 PM |
Raceline "hotter rail" ..........
Wiser to to use the standard Blacktop setup if you have the space.
[/I]
